79' Harley...PLEASE HELP
Discussion in 'Harley Driver's Club' started by jakebehr, May 3, 2015.
  1. jakebehr
    jakebehr New Member
    New Points. Brand New Carb. New Coil. New Fuel. New Fuel Filter. New Spark Plug. Spark plug & points gaped correctly. Compressions 100+. Timing Is Correct.
    Yet it only sputters every once in a while, with choke.
    How does this make sense?
    I dont know. I have the same question.
    Any replies would be greatly appreciated, kinda stuck in a rut.
    Thanks,
    Jacob
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. jakebehr
    jakebehr New Member
    Does anybody even use this website??????
  3. HotRodCarts
    HotRodCarts Cartaholic
    Actually yes a lot of people use it.
    Have you checked to see if your pumping gas to the carb? Have you tried a little gas in the carb to see if it runs?
  4. jakebehr
    jakebehr New Member
    Spark is poor. what could this be with all the parts i have replaced?
  5. jakebehr
    jakebehr New Member
    Ok, so now i jhave discovered that i have put the negative to the positive and positive to negative, my fault i guess, but the wire was red and i put that to the positive, only reason i found out was because i was looking around in the manual. could this have fried the coil or condeser?
    thanks
    jake
Share This Page
