HotRodCarts submitted a new resource:
Electric Golf Cart Battery Maintenance - Maintaining Your Golf Cart Batteries
Read more about this resource...
Electric Golf Cart Battery Maintenance:
Only add distilled water before charging if the level is below the plates. Then you would add until the plates are just covered. Then fill to proper level after fully charged.
The level will rise as the batteries are charged. So if filled to proper level before charging they will leak out of the caps while charging.
Proper level is just below the sleeve that you will see in each cell.
If your cart has a On Board Computer or OBC it's best to let...
