EZGO Electric Golf Cart Motor Wiring Diagram
Discussion in 'EZGO Electric' started by James Campbell, Jun 10, 2018.
  1. James Campbell
    James Campbell New Member
    I just purchased a 1994 EZGO medalist 36 volt golf cart. It needed new batteries and battery tray. Batteries were already removed, I replaced the battery tray. Now I'm trying to get all the wiring hooked back up. There are 4 cables running from the control boxes in the front and just hanging down in front of the axle, I'm pretty sure that they hook up to the motor, but not sure which cable goes where. Can anyone help me with a wiring diagram? Also I noticed the 2 studs on the front side of the motor have a jump cable on them.
  2. HotRodCarts
    HotRodCarts Cartaholic
    There shouldn't be any jumper on the motor studs. Take a look through the EZGO Resource section of the forum, there's a wiring diagram for your golf cart there.
  3. James Campbell
    Thank you.
  4. HotRodCarts
    No problem, you're welcome. :hattip: Let us know if you can't find the right wiring diagram in the EZGO resource section of the forum.
  5. James Campbell
    Got it hooked up, but now the solenoid just clicks when I press the accelerator. Going to buy a new one today and see if I can get it going.
  6. Glen Batchelor
    Glen Batchelor Active Member
    Check the solenoid with a continuity tester before you buy one. Take off the load contacts and diode and check across the two large studs with the tester.
  7. James Campbell
    Old solenoid was bad, but now only way it will go is if I put a jumper wire between small stud and one of the big studs on the left side of you are standing at front looking towards the rear. Any suggestions on what the problem could be? Could it be the big diode that runs between the big studs?
  8. HotRodCarts
    Does the new solenoid click when you press the throttle without using a jumper? If not I'd test the micro switch on the throttle.
  9. James Campbell
    Only clicks with use of jumper. I can drive it all over with the jump wire.
  10. HotRodCarts
    Does the solenoid click without the jumper?
  11. James Campbell
    No sir it doesn't do anything.
  12. HotRodCarts
    Check the micro switch on the throttle.
    James Campbell likes this.
  13. Patrick L
    Patrick L New Member
    I don't want to hijack this thread, but, my problem [ posted above] seems the same as James. My throttle switch seems to test fine. When disconnected and jumped. No voltage when open, full voltage [ only used 12v] when closed.
  14. HotRodCarts
    The best way to test a micro switch is with a ohm meter. You can also unplug and connect the two wires on the throttle micro switch together to bypass for testing to see if the cart runs.
Share This Page
