Fuel Not Reaching Filter
Discussion in 'EZGO Gas 4 Stroke' started by mikerose, Jan 7, 2018.
  1. mikerose
    mikerose Member
    2014 EZGO gas golf cart with Kawasaki engine. The the hose to the crankcase has good impulse. The line to the carburetor has good pressure or feels like it does anyway. But no fuel is reaching the pump I think. I can't see any fuel in the filter which is right before the pump. Tank tube is not cracked. I cranked the engine and see no fuel filling the filter. Bad fuel pump? Any help is appreciated.
  2. Nubs
    Nubs Cartaholic
    I would pull the filter off and see if it pumps, I have never been a big fan of the filter before pump but that's the way they set them up :twocents:
  3. mikerose
    mikerose Member
    i pulled filter off and still no flow. ??? order a new pump?
  4. Nubs
    Nubs Cartaholic
    Well if we're sure there is no blocked inlet / pulser lines then I would say yes.
  5. mikerose
    mikerose Member
    will a weak battery be a cause to not pump enough fuel?
  6. Nubs
    Nubs Cartaholic
    If the engine spins it should pump, you did say that you could feel the pulser line working? can you blow air from the inlet line back to the tank?, Are you sure the pickup in the tank is good
  7. mikerose
    mikerose Member
    i took pump apart and put back. looks like i have fuel flowing now but still sputters a bit. battery is at 20% charge. thats why i asked if battery will affect performance.
  8. Nubs
    Nubs Cartaholic
    Well the faster the engine turns the more/better it pumps, give the battery a good charge and try it again.
  9. mikerose
    mikerose Member
    looks like it was the battery. gave it a good charge and is back to running normal. didnt realize the battery played that big a role.
  10. Nubs
    Nubs Cartaholic
    Glad to hear its up and running, thanks for posting the outcome:hattip:
  11. mikerose
    mikerose Member
    well bad news. not working again. how many spark plugs should the kawasaki engine have by the way. removed the top plug and it was wet. motor oil smelled like it had gas in it. please help
  12. Nubs
    Nubs Cartaholic
    Is the oil level over full on the dip stick? sounds like the fuel pump is bad and fuel is getting sucked into the crankcase.
  13. mikerose
    mikerose Member
    i put new fuel pump already. then this happend
  14. mikerose
    mikerose Member
    im thinking carb needs a good cleaning?????
  15. Nubs
    Nubs Cartaholic
    It would be the next step:twocents: if the float is sticking it will flood for sure.
  16. mikerose
    mikerose Member
    i appreciate the info. will get back to you.
Share This Page
