Golf Cart Has Toe In Issue After Installing Madjax 6 Inch Lift Kit
AFVET
My 2014 Club Car Precedent golf cart has a toe in issue after installing a Madjax 6 inch lift kit.
Request for Madjax support
Just installed a Madjax 6in lift kit, following the video
Camber adjusted to spec but every time I roll the cart and recheck it's off a bit.
Toe in made sure tie rod ends are equal with the wheel centered the RT wheel is way out .... is there an adjustment to center the lift kit assembly? I have noticed similar issues but no fix. Thanks
Where did you buy the lift?
Adjust the tie rods until you have 0-1/16th toe in.
If you can't get it to that setting by adjusting the tie rods I'd be calling the company you bought the lift kit from.
