please help
Discussion in 'EZGO Gas 4 Stroke' started by ACEGOLFCARTGUY, Jan 27, 2006.
  1. ACEGOLFCARTGUY
    ACEGOLFCARTGUY Cartaholic
  2. HotRodCarts
    HotRodCarts Cartaholic
    You should have no problems wiring up any 12v radio in your cart. Basically the same as hooking one up in a car.
  3. ACEGOLFCARTGUY
    thanks. how would i do it? can i run the wires directly to the battery?
  4. HotRodCarts
    If you run the wires to the battery the radio will work with the key on/off. I always wire them that way so you can listen the the radio without the cart running and the key off. I have heard some guys say that there batteries were going dead on certain radios when the cart sits for a few days without running. I've never had this happen. I guess it all depends on the radio. The memory wire (if equipped) will have to go to + on battery if you want the clock and presets to stay in memory.
    Also be sure to have a fuse in any hot/+ wires as close as possible to the power source.
  5. ACEGOLFCARTGUY
    thanks. so i just look for any 12 volt car radio. sweet [​IMG]
Share This Page
