Star EV Rear Axle Change
Rakins0822
Anybody had to change the rear axle in a newer model Star EV? Trying to determine if the axle has a retainer clip that has to be removed in the differential or the pressed bearing and 4 bolt cap keeps the axle in place.
Zman
should be just the 4 bolts and axle flange that keeps axle in. sometimes I have had to use a slide axle hammer to get them out.
Spykstr67
Did you get it changed? I’m needing help to do the same thing
Zman
Should be a retainer plate with 4 bolts, remove bolts and pull axle, may have to use a slide hammer if axle won't come out easily.
