yamahag16a
1996 Yamaha g16a gas cart....
It's become an obsession to fix my mothers campground golf cart.
I didn't know what I was getting into.
I've replaced alot of parts in the thing ...
ok...to get it to start:
-went into the electrical stuff first...started with bench testing starter/generator, tested battery both fine.....repairing bad wiring under the cup holder and
replacing solenoid seemed to fix it, then it wouldn't last...
you could drive it a lil ways then it would sputter and stall.
I started checking fuel...
replaced carburetor, fuel filter, and fuel lines....(all but one short section...didn't buy enough fuel line)
After carb replaced it ran well.....I took it for a test drive for a good 15 minutes taking it thru the paces....slight backfire in the exhaust once or twice, but it ran fine.
Went home.....got a call that they stalled out while taking it to the trash dump and wouldn't start....then they left it sit a bit and it ran enough to get them home.
My next thought was....Ignition Coil.
but I already had a new fuel pump on order.
Installed it yesterday started the cart with myself and mom on board....started up the road running fine....got maybe 100 yards when it sputtered and stalled....I pushed it back.
Question:
Could it be the Coil even if it stalls within a minute or two into the ride? ( I thought the signs of coil failure didn't show up until it was good and warmed up)
Thanks for any opinions ...I'm frustrated from thinking it's fixed and finding out it didn't last.
Question:
