Dw89xj
I was curious if anyone has narrowed Yamaha G9 axles. I'm doing a chain drive dual swing arm rear suspension like the sand rails guys run on rocks and hill climbs. I'm basically just using the main frame of my G9 and building a mini rail off of it. In doing this I could easily regear by swapping sprockets. I'd likely use #50 roller or 530 o-ring chain. Maybe #60 or whatever o-ring is equal size.
I basically just need the center section so I can have forward/reverse. I would need drive flanges as close to the case as I can. I assume it would be like shortening any other rear axle but easier? Iirc the tubes unbolt so couldn't I just shorten then to where I want and just cut the axles down and weld the flanges in the new position?
I want to do this mostly because I like building cool stuff but also because those sand rails amazed me with this setup. If you search chain drive sand rail on YouTube you will see what I mean. I know those guys are running 38"+ tires, I'd only be using 28-30" so obviously I wouldn't be doing things as crazy as them but on the trails we run my buggy would be a little monster for rocks and logs.
Picture included is the best I could find depicting what I'd like to build. Thank you guys for any insight.
