I know this post is old, but I wanted to thank you guys. I'm in the middle of bringing a G2 back to life that I saved from rotting in a pasture after 10 years or so from what the previous owner said. I have replaced the carburetor, wiring harness, installed an electronic fuel pump, spark plug, and after I changed the oil and hooked up a new battery and battery cables, it fired right up! However, I had the hot lead for the fuel pump wired to the key switch...as you can imagine, it was always pumping fuel to the carb when the key was on and therefore flooding it out. Thank you for the instruction to wire it to the lead running from the solenoid to the starter/generator!!! It runs like a champ and there is no flooding issue now! On to new brakes and drums, paint, headlights and taillights, installing the lift kit wheels and tires, etc...hahaha
