Wow, I don't have a manual so appreciated this thread. I've done everything here except remove the front leaf spring bolt and no go. I will do that tomorrow. I was shocked at how much trouble caused in servicing this part vs the way it used to be. Several hours today and still not done. Previously, a jack under the engine mount, lift it slightly, remove to bolts, remove and install the new snubber, bolt back in place, remove jack. Clearly service was not considered when making the "weld on" cost save. I'm even thinking about making mine a "bolt on" if I can devise a way to hold it in the welded-on position by cutting off the current one, making a small part, bending it to align and then bolting it on. Thanks
