My cart is a G-29 Yamaha, 2014 with about 50 hours on it total. When I start it will drive around 100 feet and lose power and will not move. The engine will run at a very low rpm but not enough to move the cart. I drained the gas put fresh gas thinking the gas was bad but it still does the same thing. If I let it sit over night it will do the same thing. It does not have a gas filter, which I’m shocked at but a permanent filter in the tank which looks to be on the inlet side of the fuel pump. I bought it new but hardly drive it as you can see, 50 or so hours. Anybody have any ideas on this? Thanks.
