floridatrailrider
Ok, got my 95 Medalist home from the very dusty and sandy Campground after almost a year. And yes it's like a Spring Day here.
I have been having problems with the cart not having the rev up that it used to have. I have been trying the different holes, the furthest from the blue works the best, anyone mess with the hole option? Are the ramps too worn? The spring is a little different at each end, does it matter? Will a different spring give me more low end?
On to the front end, it has gotten a bit sloppy, It will rock to the side at least an 1/8, should I worry about it? Should I replace the bushings and pins in the spindle along with new wheel bearings?
The rear tires always rub, are my leaf springs or shocks worn out?
